Author Topic: can i use RADWELD for a leaking Matrix??  (Read 4435 times)
Offline GGGti75
« on: 23 February 2010, 13:58 »
I've checked out a few threads about this and it seems to be a 50/50 split.
some say don't use radweld at all and some say it works fine to seal the heater matrix. I was wondering if anyone has tried it recently and give me your thoughts please.
Cheers in advance
P.S. the condensation on the windows is bustin my tights man :angry:
Offline Horney
Re: can i use RADWELD for a leaking Matrix??
« Reply #1 on: 23 February 2010, 14:04 »
Yes you can but NO you shouldn't. It gunks up the rest of the cooling system. Get a new matrix and fix it poperly. You'll get good cooling and good heating.
nick
Offline GGGti75
« Reply #2 on: 23 February 2010, 15:05 »
yeh, i'm just looking for a quick fix till the better weather comes, i know its a pain in the ass job
« Reply #3 on: 23 February 2010, 21:16 »
Don't use radweld it will cause you loads of issues in the long run.
Offline AudiA8Quattro
« Reply #4 on: 23 February 2010, 21:56 »
Always used radwell with no issues, it will only work with small leaks.
Its not recommended to be used with an old Rover model with a small heater pipe, can't remember each one  :grin:
Offline GGGti75
« Reply #5 on: 24 February 2010, 10:45 »
Well, I used it and it seems to have done the job, hopefully, still got a bit of misting on the windows but i need to dry out the carpets.
Offline christomk3gti
« Reply #6 on: 24 February 2010, 12:38 »
not a good idea really it can easily block up the waterways all around your engine, hense hot spots. I have used it on a leaky radiator once but I knew the car wasnt going to last much longer. I wouldnt put radweld in my golf. no way ho say.  :grin:
Black 8v GTI............. Whats a Waffle Valve?
« Reply #7 on: 24 February 2010, 12:39 »
+1 never liked the stuff.
« Reply #8 on: 24 February 2010, 12:41 »
All these sealing products remain in liquid form until they reach the leaking point, so they don't tend to clog up the cooling system. Unless you put in 10 bottles  :grin:
« Reply #9 on: 24 February 2010, 12:44 »
Ok, so for eg, if you have a really thin diameter water way, the sealing stuff will not think this is a leak and seal it then??? or does it have to be in contact with lets say (air for it to seal) due to a hole somewhere...
