Author Topic: AGG Engine Code - Limp Home Mode  (Read 4205 times)
Offline slimeslab
« on: 23 February 2010, 11:49 »
Hi All,
I have looked through the common faults section and it seems that I've had most of them over the two years I've owned my car.
It's a MK3 Estate with the 2.0 AGG engine.
Previously I have changed the two probelmatic relays and the crack position sensor which was knackered - this cured the cutting out on motorways problem  :smiley:
Now however I have a new problem.
I have very lumpy tickover and I can disconnect the MAF and Hall sender plugs and the engine will still run the same. When I try to accellerate it is very hesitant until about 2000-3000 rpm and evern then seems to be lacking power.
My question is. Is my car in limp home mode??? - will limp home mode disregard all the sensor inputs and keep the engine running even when they are unplugged?
I have ordered a VAGCOM cable which should be coming tomorrow - I was just wondering if anyone else has had similar limp home mode problems?
Many thanks in advance
Martyn.
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
Re: AGG Engine Code - Limp Home Mode
« Reply #1 on: 23 February 2010, 17:52 »
Id start by thoroughly cleaning the throttle body before anything else.
Offline slimeslab
« Reply #2 on: 24 February 2010, 12:52 »
Hi again, thanks for the tip, I've had the dirty throttle body problem before. It's kept super clean now! :)
Its definately not a dirty throttle body.
Thanks
martyn.
Offline slimeslab
« Reply #3 on: 26 February 2010, 09:36 »
Checked TB last night - super clean.
Still have same problem.
Any thoughts/ideas?
Thanks
Martyn.
