Author Topic: Tyre Shine/Black  (Read 5310 times)
Offline Jimp
Tyre Shine/Black
« on: 22 February 2010, 16:13 »
I know that some of the cheaper car shampoos/polishes etc can be harsh on the paint but what about tyre shine? What reasons are there to go for a more expensive tyre shine? Is it just how long the finish lasts or are there other factors?
Not low enough mk5
Not on the road enough mk3
Offline jaydubveedub
Re: Tyre Shine/Black
« Reply #1 on: 22 February 2010, 16:33 »
Some will last longer than others.
I use Megs Endurance Tyre gel, applied with the megs foam applicator pad.
The stuff itself is a thick gel, and gives quite a deep glossy shine especially if you give it two coats about 10 mins apart. It a great product which last a long time, even in wet weather!
Also the pad is very useful because it helps you to get an even coverage without getting the product all over your hands or your rims.
2003 Passat 1.9 Sport TDI Wagon | Inky Blue | Lots of Wax
Offline dragonfly
« Reply #2 on: 22 February 2010, 16:58 »
I find some of the gels can attract dust. Chemical Guys New Look Trim gel is good. I currently use Mothers Refleciton Tire Care which leaves a nice matt finish.
Put some of the dressing in a small cup and apply it with a paint brush or spray on and wipe with a tyre applicator.
Offline Dan J
« Reply #3 on: 23 February 2010, 11:10 »
good quality tyre dressings will not only make your tyre look good but it also helps keep the rubber supple and prevent it from cracking etc but dressing them is mainly for looks really.
as said above the megs tyre gel is very good and does last well in the summer(apply it thinnly for best results)
it really isnt worth applying it in the winter though as it will come off quite quickly due to the weather and the salt thats put down on the road will strip it quite quickly tbh.
Offline Guy
« Reply #4 on: 23 February 2010, 12:27 »
Offline Dan J
« Reply #5 on: 23 February 2010, 12:46 »
looks good guy, may have to give it a try, how does it behave on different bumper/trim plastics?
have you tryed AS highstyle yet? i highly recomend it if you havent :wink:
Offline Guy
« Reply #6 on: 23 February 2010, 12:50 »
yeah... I use highstyle for valeting work... its ok but its a bit runny so I apply to tyres etc with a paintbrush and then rub over with a tyre applicator/cloth so that it doesn't 'flick' off over the paint once driven
smart gel seems to work well and last well on trim on the mk3... looks good on tyres - easy to apply. I wouldn't use it on bulk work due to the cost.
Offline PishY
« Reply #7 on: 24 February 2010, 19:34 »
u use Chemical guys new look trim gel!
works wonders!
Offline golf gti 260
« Reply #8 on: 18 March 2010, 21:27 »
what do people use on there tyre,s  :wink:
Offline Dan J
« Reply #9 on: 18 March 2010, 22:08 »
autosmart highstyle
megs endurance
these will give a high gloss but can be dulled down by putting less on the tyre.
