Golf mk2
cause of blowers not working?
Topic: cause of blowers not working? (Read 1816 times)
Cory
Here all the time
21 February 2010, 19:17 »
had a look at the fuse box today, and mine is missing the air conditioning relay.
would that be why the heater blowers dont work? if so, where can i get a relay
and do i have to get a certain one?
many thanks
Cory
Reasty
Alpine white valver.
Re: cause of blowers not working?
21 February 2010, 19:24 »
Could be a number of reasons,check the fan switch is connected and that it's getting power,also the fan itself may have packed up,this is under the passenger side lower dash tray right up in the left hand corner (as u sit in the car) also check the fuse box and make sure the fuse it ok (do this first)
Reasty
21 February 2010, 19:29 »
The aircon relay won't make the fan work and if your car dosnt have aircon then it's not needed hence why u don't have one.
Cooper_si
21 February 2010, 19:35 »
Ive never seen a mk2 with AC ? im sure some exist.
Yeah if your only getting the highest fan speed then it will be the blower resistor. If its not working at all then its either the motor or switch. Dead cheap off fleabay.
Beware of new motors tho on ebay, as i got one and it was no where near "blowy" enough !
Owned:
88 Polo GT Highly Modded (FBC), 91 Polo G40 Highly Modded (PPP), 90 Mk2 Golf Driver Modified (LWR)
NOW:
92 Mk3 Golf GTI 8v (KDD) no, i dont like the exhaust either lol
Cory
Here all the time
21 February 2010, 19:39 »
ahh, sweet cheers guys, am a newbie, so not very clued up on thing.
checked the fuse earlier and seems fine
so will have a looky at the motor etc 2moro.
thaks for the info
Cooper_si
21 February 2010, 19:47 »
The motors dead easy to get out...undo the 5 screws that hold the lower shelf in, three top and one either side. Then unclip the power cable from the motor. The motor unscrews from the housing....DONE
The resistor unclips from the motor housing, then two wires connect up inside
Owned:
NOW:
Golf mk2
