Author Topic: best way to remove my scratches??  (Read 1449 times)
Offline Ant168
« on: 19 February 2010, 16:37 »
I was 1/2 asleep when parking and results are shown.  I've already tried to polish it out but this is what's left??  Should I use sand it down, 'T-Cut' it then spray over it??
Thanks
Ant
Offline av_golf
Re: best way to remove my scratches??
« Reply #1 on: 19 February 2010, 21:06 »
t-cut will not get that out. seeing as its only the bump-strip, you may be able to just mask off the other sections, sand it down until you get it kind of smooth, primer it, get the right colour from autopaints (or similar) in rattle can form, spray then lacquer.
Offline Dan J
« Reply #2 on: 20 February 2010, 16:28 »
rub down and respray as said above but if its metallic paint then you will have to do the whole bumpstrip, metallic paint wont blend with the existing paint so you'll have to do the whole strip so it all matches.
Offline Ant168
« Reply #3 on: 20 February 2010, 16:42 »
thanks for the replies
