Golf mk2
Electric window stopped working, which colour wire do i need to find???
Topic: Electric window stopped working, which colour wire do i need to find??? (Read 1798 times)
walchy01
18 February 2010, 17:49 »
Hi there
My drivers side window has stopped working, could someone advise me which coloured wire i need to locate to check for a split, and also other than the wiring thru the door where else to check to solve the problem?
Thanks in advance
Reasty
Alpine white valver.
Re: Electric window stopped working, which colour wire do i need to find???
18 February 2010, 18:28 »
the motor has defiantly stopped working? ie no motor noise when you press the button?
weazgti
18 February 2010, 20:56 »
Get a multimeter and check there is voltage at the wiring plug on the motor when you press the switch. If there is then the motor is probably seized. Also have you swapped the switches around to rule that out.
walchy01
19 February 2010, 10:23 »
Will check the ideas suggested and should hopefully solve the issue.
Thank you
walchy01
25 February 2010, 17:12 »
Managed to check today for the electric motor noise and there is nothing, does this mean just sply replace the motor or could it be something else aswell?
Thanks
weazgti
25 February 2010, 21:05 »
regulater or motor seized most probably if you have voltage at the plug.
Every now and again mine works again so im gonna strip it out on a dry day and see if i can free it up.
sprout99
Here all the time
Reply #6 on:
26 February 2010, 08:03 »
mine was fuse ...cuased by short circuit reverse light switch
heated washers and reverse switch share the same fuse. Is fuse OK?
25th Anniversary TDi - PD
Oak green mk2
V50 D5 Sportwagon
walchy01
Reply #7 on:
26 February 2010, 15:08 »
Do u know what fuse number is?
Thanks
Golf mk2
