Author Topic: Monza II Shadow offsets  (Read 3140 times)
Offline sundaydriver
« on: 17 February 2010, 21:32 »
Ive just gone and bought some second hand DOTZ PREDATOR alloys without tyres cheap but they are 8x18 with a offset of 45 and the Monza II shadows are 7.5x18(not sure what the offset is).
The bloke i bought them from had them on his Scirocco with 8mm and 13mm spacers and also tells me im going to need the spacers as well.
Does anyone know if this is true or is he telling me porkie pie's! ALSO what size tyres will i need (225/40/18?)
Cheers Steve
2012 Golf R, APR STAGE 2+, BCS power valve TB exhaust, loba HPFP, evoms intake, Rising blue, 19" Talladegas -BMW M2
Offline Snoopy
  • Moderator
  • Geoff.
Re: Monza II Shadow offsets
« Reply #1 on: 18 February 2010, 17:57 »
ET51 the scirocco has a different offset of ET41
« Last Edit: 18 February 2010, 18:22 by Snoopy »
Mk6 GTI  &  Mk1 GTI
34 years of GTI ownership.
« Reply #2 on: 18 February 2010, 19:21 »
Thanks snoopy
Offline simonpolly
« Reply #3 on: 18 February 2010, 20:10 »
What is the offset ? what does this mean ?
Golfgti build quality is average at best.
Offline Snoopy
  • Moderator
  • Geoff.
« Reply #4 on: 18 February 2010, 20:15 »
Mk6 GTI  &  Mk1 GTI
Offline simonpolly
« Reply #5 on: 18 February 2010, 20:17 »
Thank you :wink:
Offline Snoopy
  • Moderator
  • Geoff.
« Reply #6 on: 20 February 2010, 08:48 »
Sorry i missed the second part of the question. You can reuse the 225 tyres ok if you want or go upto 235.
use
http://www.venommotorsports.com/library/tirewheelcalculator.asp
to calculate the tyre size and also wheel offset problems you may encounter.
« Last Edit: 20 February 2010, 08:51 by Snoopy »
Mk6 GTI  &  Mk1 GTI
« Reply #7 on: 20 February 2010, 09:13 »
use
Top man! Thanks
