Author Topic: fuel pipe route from back of the filter under car 16v  (Read 817 times)
Offline ben harcombe
« on: 17 February 2010, 20:58 »
Ive changed the fuel filter and now its leaking badly  :shocked: :shocked:
First of all where exactly does the pipe run in the haynes it says it goes to under the bonnet to the metering head (airbox)
does it go around the tank or under it  :undecided: :undecided:
Its the pipe closest he rear of the car and its metal
Anybody else had this pipe leak and fixed it themselves please give me heads up
Re: fuel pipe route from back of the filter under car 16v
« Reply #1 on: 18 February 2010, 11:03 »
pipes are like so:
fuel pump -> accumulator -> filter -> engine
did you refit the old copper washers, or replace? or is it the actual pipe thats split
