Author Topic: vagcom interface not found !!!!!  (Read 11713 times)
Offline madmk4
« on: 17 February 2010, 20:16 »
have searched this one and followed andy s tutorial on here and stilll no luck . i bought the lead from ebay and it came with a disk so installed that and done the com 3 and it comes up with port in use interface not found . im running vista vagcom 409.1 please help b4 laptop gets run over  :laugh: :smiley:
Offline ade_aidy_ady
Re: vagcom interface not found !!!!!
« Reply #1 on: 17 February 2010, 22:15 »
had same kinda problem ........... right click on vagcom on ur desktop........"shortcut"......click run as administrator......
try that and maybe also need to tweak options under control panels - device manager
Offline golf-sib
  • Турботазик
« Reply #2 on: 17 February 2010, 22:42 »
You sure the cable is 100% on com3, as you can enter device manager and change com numbers, as when I plugged cable into windows 7 it set it as com5 and there is no com5 option, so I changed the com5 to a com3 in device manager and told vag-com to use com3.
Also the test will fail to find interface unless the vagcom cable is plugged into car with ignition in "on" position.
VW Golf - k03 AGU - 200BHP
1.8T AGU..
R135
  24
Offline madmk4
« Reply #3 on: 18 February 2010, 08:32 »
cool il ty that tonight  :smiley:
Offline madmk4
« Reply #4 on: 18 February 2010, 18:40 »
i gave up with the version 409.1 that cam with the lead of ebay i installed the 311 version and all is ok but im still limited to what i can do . is it possible to delete the fault code to c if this returns
Offline Jay
  • balding fat cvnt
« Reply #5 on: 18 February 2010, 20:48 »
In 409.1 you click 'Clear Fault Codes' where the faults are listed when you scan the module.
Also try update your drivers using http://www.ftdichip.com/Drivers/VCP.htm
Offline madmk4
« Reply #6 on: 18 February 2010, 21:27 »
computers they have a mind of there own i reinstalled version 409.1 after installing the 311 one and hey presto it works . now its asking for it to be verified  :laugh:
Offline Jay
  • balding fat cvnt
« Reply #7 on: 18 February 2010, 21:33 »
Did you use 409.1s or 409.1us? Or did you download it from their website, if so which did you download?
Offline madmk4
« Reply #8 on: 18 February 2010, 21:39 »
the us one came with the ebay lead that did nt work so i downloaded it from ros tech website and no thats the one im using
Offline Jay
  • balding fat cvnt
« Reply #9 on: 18 February 2010, 21:41 »
The left or right version ?
You should use the left version "For  MODERN SERIAL Interfaces".
The right hand version version is if you're using the Ross Tech cable and not an ebay special.
