Author Topic: Here they are...Compression test results! NEW FIGURES PG 5!  (Read 10106 times)
VW BUSH
Re: Here they are...Compression test results!
« Reply #30 on: 19 February 2010, 13:09 »
Why dont you test the actual pressure in the crank case........................ you might be supprised
My car has 145k on it gets a bit of oil in the TB, most is carried by fuel in the oil as it evaporates
your not burning oil
your car runs fine
Whats the problem?
 :smiley:
Offline Khare
  • The bear that khares
« Reply #31 on: 19 February 2010, 13:29 »
Well well well, what do you know.
Compression tester from ebay is faulty  :rolleyes:
Gets to about 50 psi and just gives up. My guess is that the crappy adapter for the smaller spark plugs is leaking, as it looks pretty sh!t quality  :rolleyes:
Have sent the seller a message asking for a replacement for a working one or a refund. So for now, all on hold.
Car runs a bit flat, seems to lack some power. For now it's OK, but I will re-do the test when I've got a working tester.
Offline axewielder
  • 95 dragon 8v
« Reply #32 on: 19 February 2010, 14:07 »
what make is it? there is an o ring in between thread adapters on mine
http://cgi.ebay.co.uk/Laser-Quality-Compression-Tester-2516-New_W0QQitemZ120526521928QQcmdZViewItemQQptZUK_Diagnostic_Tools_Equipment?hash=item1c0ff0c648
laser one here for tenner, ive got a gunnsons one
« Last Edit: 19 February 2010, 14:10 by axewielder »
Offline Khare
Offline axewielder
  • 95 dragon 8v
« Reply #34 on: 19 February 2010, 14:37 »
am-tech arent terible for quality got a nice adjustable spanner from them but if this is faulty id get a refund+ buy a laser/gunnson other reputable auto tool maker
Offline Horney
« Reply #35 on: 19 February 2010, 14:50 »
I've got a gunson one and it's given me 10 years of superb service.
nick
Offline AudiA8Quattro
« Reply #36 on: 19 February 2010, 15:41 »
I think mine is a gunson too, had it for 10 years, its not let me down but i've only used it a few times.
« Reply #37 on: 19 February 2010, 20:43 »
It is a long shot but your saying it lacks power etc, maybe you have a sticking valve.
Offline Khare
« Reply #38 on: 19 February 2010, 20:45 »
mmmmmm don't know, but it's not lacking too much power. Still quick, just not AS quick  :grin:
« Reply #39 on: 19 February 2010, 21:00 »
Did you do the original compression test yourself?
