Author Topic: Clock display  (Read 4138 times)
Offline Davstylee
Clock display
« on: 15 February 2010, 17:17 »
Hey people this may sound really stupid, and I apologise in advance for sounding this dumb, but can you change the clock display on the low line display from the 24 hour format to a 12 hour format?
Thanks in advance and I hope you all weren’t laughing too hard at my stupidity.
Mrk V, GTI, 3dr, DSG, heated seats, winter pack, cruise control, rear parking sensors and now thanks to GizzyWizzy and SteveP in the MK6 section a RCD 510. Awesome!
Offline Davstylee
Re: Clock display
« Reply #1 on: 18 February 2010, 07:05 »
Wow 91 views but no responce? Is the question really that stupid ha ha?
Offline ub7rm
Re: Clock display
« Reply #2 on: 18 February 2010, 07:52 »
I think the problem is no one knows one way or the other - certainly its not anything I've thought of doing myself and I don't think I've seen any mention of this in the manual.
Which leads me on to ....
Have you checked the manual?  :tongue:
2020 BMW 128ti
2017 Golf GTD Estate
Offline FamilyDub
Re: Clock display
« Reply #3 on: 18 February 2010, 09:00 »
If you have highline MFD, i'm sure you can change the units; mph/kph, 12-hr, 24-hr, etc...
MKV GTI | Reflex Silver | 5-dr | Anthracite 17" | Manual | Highline MFD | Cruise | Revision 'D' DV | Dirty Pipes |
The GTD is like a blow up doll. The GTI is like a proper woman. Sure the doll might last longer, and the woman might have higher running costs, but which would you rather have?
Offline Ed30DSG
  • Edition 30 - gone - Audi S3 here
Re: Clock display
« Reply #4 on: 18 February 2010, 10:58 »
Or prob using VCDS if you don't have highline, thought it might be in here, but I can't find it .... http://dpham00.info/gti/vagcom/vagcom%20info%20for%20mkv.pdf
Offline Davstylee
Re: Clock display
« Reply #5 on: 18 February 2010, 11:21 »
I had a quick flick through the manual, but didnt see anything.
Not a majour problem, just would like it in 12 hr format.
I have the low line display.
2nd quick question, is it easy to change to the high line display? Im guessing no and would be a pretty majour job to do if it can be done?
Offline scotland67
Re: Clock display
« Reply #6 on: 18 February 2010, 12:30 »
I beleive you only get the highline computer display with the multifunction steering wheel which thankfully I ordered as an option on my mk5. New car has it as standard fit I see.
Offline FamilyDub
Re: Clock display
« Reply #7 on: 18 February 2010, 12:39 »
^^^Wrong. I have highline and a poverty spec wheel.
I'd be very surprised if there's no way to change the display on your car, at all...? I have been wrong before, though...
Offline Komenda
Re: Clock display
« Reply #8 on: 18 February 2010, 12:41 »
Get yourself a highline set of clocks and someone who is pretty trick at VagCom and you can swap them over. I believe you need to recode the immobiliser and update the mileage which are the tricky parts.
Offline ub7rm
Re: Clock display
« Reply #9 on: 18 February 2010, 13:05 »
^^  As above, physically changing them over is pretty easy.  How difficult the coding part is depends on the year of manufacture of your car and the clocks.  For a certain age its a dealer only job but the earlier ones can be done by someone competant with VAGCOM and another piece of software.
2020 BMW 128ti
