Author Topic: wet floor mat  (Read 2343 times)
Offline valintino46
wet floor mat
« on: 14 February 2010, 08:51 »
drivers side floor mat is getting wet, same spot all the time ive got no sun roof all windows are shut,underneath is solid and is getting wet being stationed, i know from having a mk2 some times the roof drains can block, just wondered if anyone else has had this prob? :cry:
Offline Deano2711
  • 1992 VR6
Re: wet floor mat
« Reply #1 on: 14 February 2010, 09:34 »
There are two drainage holes under the front scuttle panel that get blocked. Remove the scuttle panel and they are located in the inner wing. Clean them out and then test by pouring water down the hole....it should come back out at the bottom of the wing. If not that then it could be coming in through the door if the plastic is ripped or removed.      Cheers      Deano
Offline Khare
  • The bear that khares
Re: wet floor mat
« Reply #2 on: 14 February 2010, 11:28 »
also have a look at the pollen filter. Check to see if it's wet as that's were water was coming in on my old MK2.
Offline valintino46
Re: wet floor mat
« Reply #3 on: 14 February 2010, 11:53 »
cheers for the info, i love this forum, viva la golf!
Offline bored_Welsh_lad
Mk3 Golf Gti:Full Milltek system and Decat,K&N filter,mk2 Cam,-1.5 degree camber shims, borbet a's, toyo proxies,hot tuning coils, brembo vented discs, greenstuff pads...Soon to have Eaton Power
mk3 16v 5dr Gti,mintex extreme pads,drilled/grooved discs,lowered,cat back powerflow system,omp panel filter with modified airbox,debadged grill, started prep for spraying, lots to come :D
Bumper Vents :D
Offline MotorPsycho
  • I drive a 2000bhp dragster, so what ;)
Re: wet floor mat
« Reply #5 on: 26 November 2010, 07:04 »
Could be leaking heater matrix? Where is the wetness and does it smell/feel like antifreeze?
1983 mk1, 2.0, TSR pack C head, Eaton M45 - work in progress
1990 mk2 GTD, boost, fuel, soot
16v GTi mk3; chilli red, 16" Audi Speedlines, coilies
1934 Ford Dragster, 200mph in 6 seconds.
Offline Stirring Moose
Re: wet floor mat
« Reply #6 on: 26 November 2010, 18:25 »
Viva la Golf? Surely you mean Golf uber alles?! :grin:
On the subject of the leak, have a look around the top edge of the windscreen. Mine leaked through here due to corrosion of the steel under the seal, the water making its way down through the car and into the rear footwells.
S.M.
Love and hate, war and peace, joy and sadness... all just crap that happens between trackdays!
