Author Topic: Lacquer scratch.  (Read 2598 times)
Offline Coolhandluke
Lacquer scratch.
« on: 13 February 2010, 18:19 »
Whats the best method of removing a couple of surface scratches in my lacquer ?
Whats the best scratch removal polish to use?
Offline Dan J
Re: Lacquer scratch.
« Reply #1 on: 13 February 2010, 18:27 »
how deep is it?
if its too deep then no amount of polish will remove it :sad:
have a look at my scratch repair thread in the detailing section ( in the faqs and guide section at the top)
« Reply #2 on: 13 February 2010, 20:00 »
Its barely hair thickness deep,will have a look at your suggestions,thanks.
« Reply #3 on: 13 February 2010, 20:15 »
Cant see the FAQ section,where is it?
Offline Dan J
« Reply #4 on: 14 February 2010, 01:32 »
Detailing guides and faq
useful threads for detailing nerds!
Moderators: Rhyso, Guy
at the top of the page :wink:
Offline Dan J
« Reply #5 on: 14 February 2010, 01:36 »
from your description above, a rotory or a DA machine is best for removing scratches, if you havent got any of those then you could have a go by hand using a medium to fine compound rubbing in a circular motion with a soft pad using light to medium pressure going across the scratch.
« Reply #6 on: 14 February 2010, 13:03 »
Thanks for the advice and info will give it a go,would some T-Cut be suitable?
« Last Edit: 14 February 2010, 19:06 by Coolhandluke »
Offline cuprajake
« Reply #7 on: 14 February 2010, 19:47 »
if your finger nail will catch in it you may struggle, better option would be to buy soe cheap lacquer in a spray can, spray some in the lid, then use a fine brush to touch in, once dry take down level with 2000 grade paper then use a machine or hand to polish it up, but be very carful as you can rub through
« Reply #8 on: 14 February 2010, 19:54 »
Finger nail barely catches it , maybe will disappear through time with normal polishing,will see how it goes.
