Author Topic: Indicator stuck on constantly  (Read 1325 times)
Offline GregUK
  • 2001 Golf GTI 1.8T AUM 150bhp in Diamond Black
« on: 13 February 2010, 15:16 »
Hi all
I'm having a bit of a problem with my nearside indicator: it's stuck on constantly (i.e. not flashing).
I've changed the relay (hazard switch) for a brand new one, but that didn't solve it. The 3 indicator bulbs are all fine (front, side and rear). If I disconnect the relay and remove both the indicator and hazard fuses, it still remains lit. The only way to make it go out is to disconnect the battery.
I'm running out of ideas. Any suggestions welcome!
Thanks :smiley:
Offline richw911
Re: Indicator stuck on constantly
« Reply #1 on: 13 February 2010, 15:19 »
Do you have the correct bulbs in all three? If not this could cause a short.  :undecided:
Earthing fault?
Offline GregUK
« Reply #2 on: 13 February 2010, 15:22 »
Earthing fault?
Yeah, the bulbs haven't changed since the fault occurred.
It's interesting you should mention an earthing fault. The car has recently had a gearbox rebuild, which is when the problem started. Do you know if there are any earth connections around the gearbox/clutch area that might have been disturbed?
Offline GregUK
« Reply #3 on: 13 February 2010, 23:07 »
Does anyone know of a guide for checking the earth on a Mk4 Golf?
Thanks :smiley:
