Author Topic: Temporary lack of power  (Read 4275 times)
Offline mikemk4gti
« on: 12 February 2010, 21:16 »
 Took the car for a quick spin yesterday, pulled away from a roundabout and got to 5500 rpm in second and then when i changed to third there was no power, so slowed down dropped down a gear and still gutless.
 Pulled over and turned engine off and on, drove off and still gutless. could hear the turbo spinnging but wasn't at full chat. after about a minute of driving all was back to normal and its been fine since.
 Any ideas?? the engine light didn't come on.
51 mk4 gti 1.8t AUM | 05 Audi A3 3.2 Quattro S-Line | 01 A3 1.8t Sport | 02 Golf 25th Anni 1.8T | 03 mk4 GTI AUQ | 05 Leon Fr TDI 150 | mk2 golf gti 8v | 01 Audi S3
Back in my old MK4 '01 AUM!
http://uk-mkivs.net/forums/t/400214.aspx
VagCom, VagTacho, MTE, Needles, Key coding, Locked beeps etc availab
Offline MaXXeH
  • Golf MK5 GTI
Re: Temporary lack of power
« Reply #1 on: 12 February 2010, 21:17 »
blown a pipe?
have  a look for leaks
Offline mikemk4gti
« Reply #2 on: 12 February 2010, 21:32 »
that was my initial thought but now its fine??
Offline MaXXeH
  • Golf MK5 GTI
« Reply #3 on: 12 February 2010, 21:45 »
unless it went into limp mode, you need vagcom.
Offline oliver07
  • golf gti T 200BHP
« Reply #4 on: 13 February 2010, 08:34 »
when mine webt into limp mode the engine light would come on and stay on till vag was used to turn it off. possible coil pack breaking down.
Offline barry-gti
« Reply #5 on: 13 February 2010, 08:49 »
mine never gets any warning lights for limp mode. was it boosting between 5-10 psi ??
Offline mikemk4gti
« Reply #6 on: 13 February 2010, 11:20 »
 I have vag com but haven't had chance to check for codes yet. I thought the engine light would of come on if there was a fault?
Offline DarkGti
« Reply #7 on: 13 February 2010, 11:33 »
sounds like a boost leak to me
Offline mikemk4gti
« Reply #8 on: 13 February 2010, 11:36 »
but why would it be ok now?
Offline DarkGti
« Reply #9 on: 13 February 2010, 11:40 »
try doing the same again see if it happens! the reason i say it is because you might have a boost pipe split opening up at high boost!
