Author Topic: Oil leaking from Drive shaft boot  (Read 4019 times)
Offline Sam
  • Sam I am
Re: Oil leaking from Drive shaft boot
« Reply #10 on: 11 February 2010, 22:10 »
Its either the inner seal or the molly grease is fooked. On my out cv the grease was more like oil but inner was fine so... hmm!?
Offline Chappio
« Reply #11 on: 11 February 2010, 22:38 »
Thanks lads. Just 2 questions:
1) will i need to drain the gearbox before doing any of this?
2) Where will I get the spine tool to get the drive shaft off?
Offline raferackstraw
« Reply #12 on: 11 February 2010, 22:47 »
if you jack car up on drivers side only then i dont think you'll need to drain oil
the spline tool can be got from any decent motor factors however if you look on the link you will need summat to release spring pressure on the flange to remove circlip
wayne gardner smokes one rothmans too many
500cc 2stroke bad for ya health
Offline Chappio
« Reply #13 on: 11 February 2010, 23:00 »
Yeah had a read through it. Somebody on here must have changed one. I would be interested to know what they used to release the tension on spring?
« Reply #14 on: 11 February 2010, 23:03 »
big clamps or get someone to make up a tool  :wink:
