Author Topic: Parcel shelf supports 16V GTI 91 H plate  (Read 1106 times)
Offline walchy01
« on: 10 February 2010, 19:50 »
Evening all
I am trying to fix some new parcel shelf supports in my car, but i am having trouble as present, i need to thread the seat belt thru the supports in both shelves, anyone advise me on this is done please??
Had the seat belt unbolted at the side of the passenger bench seat but still no joy, any advice will be very much appreciated.
Thanks in advance.
Re: Parcel shelf supports 16V GTI 91 H plate
« Reply #1 on: 10 February 2010, 19:55 »
undo it at the other end, it all threads in from underneath!
Offline jezza16v
« Reply #2 on: 10 February 2010, 19:59 »
You have to take it off at the rear quarter pillar as well, then it all runs through the slot in the shelf, a bit tight, iirc I think you can remove the black plastic insert in the shelf slot to make it a bit bigger. Fiddley but quite easy. You don't have to take the inertia reel part in the boot off.
Offline walchy01
« Reply #3 on: 10 February 2010, 20:35 »
Brilliant, thanks for the help, sort that Friday when it stops snowing :sick:
