Author Topic: compression test  (Read 1188 times)
Offline aminorthreat1
compression test
« on: 10 February 2010, 17:37 »
i've got a suspected blown head gasket on my mk3 gti ABF, its done 98k and the coolant is boiling over. im gonna do a compression test tomorrow and i need to know what each cylinder should be running at.
Offline javalin
Re: compression test
« Reply #1 on: 02 March 2010, 19:54 »
150+ psi ish.
James
You only ever need two tools in life. If it moves and it shouldn't use Duct Tape. If it does not move and it should, use WD40.
Offline AudiA8Quattro
« Reply #2 on: 02 March 2010, 21:19 »
What were your results?
« Reply #3 on: 04 March 2010, 08:25 »
all around 180ish i think it was a few week ago now, havin a nightmare with the cooling system: http://www.golfgtiforum.co.uk/index.php?topic=146316.0
