Author Topic: Alternator wire melted...  (Read 6103 times)
Offline Mr Blue
« on: 09 February 2010, 23:01 »
Hello
Ive done a search and got some results but its not all clear. I have a mk4 1.8T 2001.
Today the black alternator wire has melted and lucky the fuse box (ontop of the battery) survived. Engine cut out. total loss of power. If I move the black cable, the engine will start.
a) Could it be the climate control causing this overload and melted the wire?
b) Is it just a case of a common faulty cable?
c) Alternator regulator faulty giving out too much amps/volts?
I did take the battery out to change the headlamp bulb a few weeks ago. Could it be a lose battery terminal thats caused this? Im sure i did the terminals up tight but might not be tight enough?
Has anyone got part numbers for the following
*alternator cable
*the fuse box
Thanks :smiley:
Offline richw911
Re: Alternator wire melted...
« Reply #1 on: 09 February 2010, 23:10 »
I would say a faulty Alternator  :undecided:
Not sure how you can check now its melted?
Offline tg1
« Reply #2 on: 09 February 2010, 23:13 »
is the black cable earth or power?
my first thought was ropey earth? you getting any unusal problems with the electrics, dimming slow windows, rev counter jumping?
sounds to be shorting out, but i'm no car sparky
and to test it just replace the broken wire with one that is similar gauge, if it works - broken wire
Offline richw911
« Reply #3 on: 09 February 2010, 23:14 »
True a few lads have had dodgy earths  :smiley:
Offline tg1
« Reply #4 on: 09 February 2010, 23:19 »
could always use it as an oppertunity to upgrade them to thicker gauge, and maybe a voltage stabilizer?
dunno if it'll do much good mind but worth a thought. i think its pretty much just a bunch of extra earthing points
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #5 on: 09 February 2010, 23:23 »
my mate had this, replaced the fuse box and all is well. Apparently it can be caused by the actual cable breaking down and drawing too much current
Offline Mr Blue
« Reply #6 on: 10 February 2010, 17:47 »
A bit of a crap design for a cable. Surely something is causing this cable to fail?
chers. Ill give that a go first :smiley:
Offline Mr Blue
« Reply #7 on: 13 February 2010, 16:50 »
Changed the cable. What a pain in the a5s of a job for just a wiring loom!
That 8mm P clip is a pain to get to without removing the alternator. Really cant stand working on the mk4 :angry:
Under closer inspection the battery fuse box has also melted. Great :rolleyes:
