Author Topic: Advice Plz; Battery Going Flat In a Couple Of Days....  (Read 847 times)
Offline X4MGS
  • VAG Parts SNOB!!!
« on: 08 February 2010, 23:54 »
I have an issue at the moment thats getting on my nerves....   :shocked:
Have had a new battery fitted 2 months ago so I assume its not that... But I have fully charged it and taken it out of the car to make sure its holding its charge...
So assuming its not the above what else is a common issue with the battery going flat after a couple of days of standing???
The Car has a Toad Alarm, brand new stereo (I have heard that some older head unts can flatten a battery)...
Could it be anything else...????
Thanks!!
 :rolleyes:
For More Info Click To See;
Offline 6foot6
Re: Advice Plz; Battery Going Flat In a Couple Of Days....
« Reply #1 on: 09 February 2010, 01:19 »
you got a Volt Meter?
Put the battery in, run the car up , make sure its charging at 13.7 or so volts.
Switch off
keep the volt meter on the battery and see if the voltage is being sapped ( a good 12v batt should sit at about 12.4 volts just sitting in the car) if it starts to drop , then its a process of elimination.
You can try simple things like removing fuse 1 at a time and rechecking the voltage and see if it stops dropping.
Remove you stereo - does it stop dropping?
Disconnect the plug from the Alternator - does it stop ?
etc
Golf GTi 8v Alpine white - Project track shlag - TLC needed - KnN/Scorpien full system oval tail pipe, rust here and there.
1991 Toyota MR2 MK Revision 1 Turbo, rev 3 LSD, CT20b Turbo, HKS Exhaust, Blitz Downpipe 244HP@the wheels @ 13psi - 12.9 SQM :D
1994 BMW 730 V8 fully loaded 220BHP
Offline X4MGS
  • VAG Parts SNOB!!!
« Reply #2 on: 09 February 2010, 01:49 »
Yeah I do....
Looks like I'll be out in the cold tomorrow!!!!
Thanks
