Author Topic: Lubricant quantities  (Read 2615 times)
Offline irmscher
  • Mobile Engine Tuning www.premiertuning.com
« on: 08 February 2010, 14:03 »
Guys,
The search function isn't giving me what i need to know on this topic..
Planning on servicing our GT TDI 150 at some point in the next few weeks.  I'm probably going to order a Haynes manual as I can't find a decent online workshop manual..
Can someone please confirm:
Gearbox oil - which one and what quantity is required in this gearbox
Engine Oil - I know I need to use PD oil, is 5-40 the right viscosity?  What is the required quantity in this block?
There's a How To in the general MK4 section, but the pictures have disappeared.  I've got a set of Gearbox drain plug keys and I've done gearbox oil before on my Accord so I'm confident with it.
Is there anything specific I need to know/watch out for?  Are the drain and filler plugs easily accessible?
Thanks in advance.
Mobile Engine Chiptuning & Remapping Specialists
Cars tuned from £199 at base
info@premiertuning.com or Facebook
Offline Steve_PD
Re: Lubricant quantities
« Reply #1 on: 08 February 2010, 17:52 »
for the oil and filter get them from the dealers, oil is £25 for 5 liters and you need 4.5, fuel filter and oil filter comes to £28
as for gearbox oil change I dont know as Ive never done it
Offline irmscher
« Reply #2 on: 08 February 2010, 18:12 »
Thank You Steve :smiley:
Ordered the Haynes manual today so I'll have a look in there for geabox oil capacity.
Offline irmscher
« Reply #3 on: 08 February 2010, 18:14 »
Just another point - when we had the MK3 we normally used GSF for parts.
Would you advise against it for the TD?  Should we be buying from the dealers now?
Offline Steve_PD
« Reply #4 on: 08 February 2010, 18:21 »
I use the dealers, its not much more expensive, the oil is one of the cheapest you can get
Offline irmscher
« Reply #5 on: 17 March 2010, 15:30 »
Offline golfmk4owner
« Reply #6 on: 17 March 2010, 15:47 »
Well i have a gt 130, and it needs vw505.01, i presume yours would be the same and the ad says it meets vw 505.01.... so im thinking yep! Sounds fine to me!
2005 GT TDI 140 - Standard as F@k
