Author Topic: cняis's orange mk2 VR6 - Dash out P.42  (Read 181949 times)
Offline cняis
Re: cняis's mk2 VR6 - AKA Christine
« Reply #40 on: 06 May 2010, 13:34 »
Was going to say - they can do TRW brand new non exchange stuff - I got a pair of brand new rear mk3 calis from them the other week.. using the right numbers its hell of a recource using them as middleman to TRW.. Brand new carriers also FTW! :smiley:
just bought recon rear calipers. DOH! these didnt come with the carriers either. Carriers were fine but the internal hex carrier bolts are worn and i could do with some new ones, but genuine dont do them seperately!  :angry:
I think i can safely say that will do! :cool: love the colour as well! get it cleaned up and it will look so good!
cheers love!
Offline mattneck(Beavis)
  • Bristol's Own (DJ) Beavis ;-)
« Reply #41 on: 06 May 2010, 16:36 »
Ive actually got a pair of carriers going spare after i fitted new.. if you pop up youre welcome to throw them in the mix with the other stuff!
Sig Removed. No Longer Applicable. New Sig? Nah. Not Yet..
Quote
Sharpo says: (16:57:39)
to be honest i dont doubt that half ggti users have a shortcut on their desktop for sharpie's last posts
Offline cняis
« Reply #42 on: 06 May 2010, 18:19 »
with the bolts?  :kiss:
« Last Edit: 06 May 2010, 22:41 by cняis »
Offline cняis
« Reply #43 on: 06 May 2010, 22:55 »
Got sick of 15mpg so today we fitted a new NTK (NGK) lambda sensor, the old one was only fitted for around 12 months but was a cheap copy.
The decat pipe was also modified today as the lamda sensor mounting hole was sitting too proud of the pipe, so only the tip of the sensor was in the flow of exhaust gases  :lipsrsealed:  probably didnt help with the emissions/running rich issue. the sensor mount was shortened accodingly  :cool:
MOT emissions readings a month ago were 4.05 CO (fail) and subsequently 3.45 CO (marginal pass) on the retest. Once warmed up i'm now getting CO readings of 0.6 to 1.1 - which is pretty good for a car with no cat  :smiley:
there may still be temp sensor or thermostat issues cos it took an age for it to lean out (i.e. think its warm enough to come off choke). probably my fault for having a low temp t/stat fitted  :lipsrsealed: but at least it wont be a constant 15mpg any more  :grin:
Offline cняis
« Reply #44 on: 09 May 2010, 00:10 »
thanks to mattneck(Beavis) i have a host of new interior bits to fit in the morning, thank you  :smiley:
piccies before and after when ive finished :afro:
other than that i made it to bristol and back (80 miles) without a hiccup, good times!
Offline cняis
« Reply #45 on: 09 May 2010, 16:39 »
ok so mainly been tidying up over the last few weeks.
needed to get the central locking working off the alarm remote, as this suddenly stopped operating. traced it to this:
worn through wiring  :huh:
cut it out and soldered/heatshrinked the wires
it still wouldnt work  :angry: so had to dig the alarm out to trace a blown fuse on the alarm loom:
yeh so thats a right mess! once i convert my replacement centre console to a Votex style one i'll tidy the alarm wiring up  :cool: One of the reasons for a Votex style console is to use one of the DIN slot covers as a back plate for the start switch rather than the aluminium effort thats jammed into the ashtray at the moment:
  :sick:
this shouldnt take much to fit, although you need to modify an original console so hence getting a replacement:
Then i went about sorting the 10v issue on the main loom which feeds pretty much everything, in the end it resulted in the car being stranded as it wouldnt start.
traced it to the terminal block in the engine bay (as battery is in the boot), one of the cables was burnt through as it was too thin  :angry:
then i visited mattneck(Beavis) for some interior bits, including new centre console, handbrake cover, scuttle tray etc
(plus a whole load of screws!)
didnt use one of the switches on the dash:
so got a new switch blank:
handbrake was missing its trim:
sorted:
Rear strut top was missing a cover but got this from mattneck too, couldnt be arsed to take a pic of this  :lipsrsealed:
also fitted the missing screws into the dash undertrays/clock surround as these were missing.
amongst the horde i collected yesterday was a drivers side footwell kick plate (top half) as this went missing in our workshop  :rolleyes: but i cant fit it as im now missing the big plastic nut!  :angry:
« Last Edit: 09 May 2010, 16:43 by cняis »
Offline JC
  • Back in the North.
« Reply #46 on: 09 May 2010, 16:52 »
getting there slowly chris :afro:
Offline cняis
« Reply #47 on: 09 May 2010, 16:58 »
very slowly, still havent cleaned it but bonnet want a proper polish as its a bit cloudy.
also the timing chains/guide/tensioner want doing eventually, tickety tickety!  :laugh:
Offline Dan34
  • VTEC Powerzzzz
« Reply #48 on: 09 May 2010, 17:04 »
You and me both  :grin: :cry:
Offline cняis
« Reply #49 on: 09 May 2010, 17:17 »
group buy!!  :grin: :laugh:
