Author Topic: cняis's orange mk2 VR6 - Dash out P.42  (Read 181952 times)
Offline cняis
Re: cняis's orange mk2 VR6 - AKA Christine - new bits page 26
« Reply #260 on: 25 October 2010, 20:37 »
Chris I took my PAS pipe over the front mount and it sits nice there and then cable tied the rest to the slam pannel its much safer and neat instead of it hanging near bottom of the bumper?
Jay
Looking good though!
i see what you mean but the section of pipe leaving the reservoir is cable tied to the cross member, then it runs through the triangulated mid section of the front cross member (rad support) so the centre is secure and protected, and the last piece to the pump wont move. it sits higher than the base of the pump, the VR6 lump sits low anyway  :shocked:
i think the pic is misleading, it seams to dangle lower than the pump which isnt the case. plus its not floppy (oo-err!)
i know it could be neater routing it behind the lower section of radiator/across the top of the cross member BUT i was a bit time constrained on saturday  :sad:
Offline clipperjay
« Reply #261 on: 25 October 2010, 20:45 »
Yeah you know what you're doing fella. I sometimes forget you have a VR6 in there, the clearance is proberly better than mine, but I've got one inch from spliter to floor too low for any dangling pipes  :laugh:
Offline cняis
« Reply #262 on: 25 October 2010, 20:46 »
 :shocked:
my sump would be pummelled by speedbumps if it were that low!
Offline VR6_ROB
  • Mk2 VR6 / Corrado G60
« Reply #263 on: 25 October 2010, 20:48 »
could you not shorten the pipe and stick it back on
looks good though mate just been reading a few pages on this not looked for a while
shame about door handles some bastards out there
what crossmember are you using? i got a raddo one cant find solid mounts
good work :cool:
Offline cняis
« Reply #264 on: 25 October 2010, 20:59 »
shame about door handles some fatherless sons out there
good work :cool:
its a standard mk2 cross member now from a scrap mk2, cleaned up and hammerited. fitted a solid mount as sold by Duff on mk2vr6.com
http://mk2vr6.com/board/viewtopic.php?f=12&t=4325
theyre £50 and fit beautifully. i copper slipped the bolts (didnt loctite them), but checked today and they havent worked loose at all.
the original crossmember was a mk2 with the centre of a mk3 crossmember welded in, and a chopped down mk3 front mount. it didnt line up right cos i had a job getting 5th gear, and on hard left turns the auxillary pulleys rubbed the chassis leg.
Offline clipperjay
« Reply #265 on: 25 October 2010, 21:03 »
 :shocked:
Go and have a look at the arch in my project page chris  :laugh:
Offline cняis
« Reply #266 on: 28 October 2010, 19:41 »
Exhaust noise:
http://www.youtube.com/watch?v=MakTNTOWMTA
only a short vid as neighbours might not appreciate it  :lipsrsealed:
Its now runner hotter as the low temp thermostat was causing it to run at 70 degrees. With a new stat it now sits at 80 degrees and seems to warm up quicker. Should be slightly better on fuel now!
Also butchered a fuel flap (from tony_ack, thanks!) for its locking pin and plate, prised it off and stuck it to my fuel flap  :smiley:
« Last Edit: 28 October 2010, 19:44 by cняis »
Offline dom
  • Back in a Mk4
Re: cняis's orange mk2 VR6 - AKA Christine - exhaust vid p27
« Reply #267 on: 28 October 2010, 19:47 »
Loving that exhaust note  :cool: :cool:
Offline cняis
« Reply #268 on: 28 October 2010, 19:49 »
shame the phone records crap video/sound  :grin:
you cant hear the popping!
Offline Dec
« Reply #269 on: 28 October 2010, 21:36 »
Mmmm Sounds sweet!
Quite funny actually, found a video I did of my old mk2's exhaust on my youtube account earlier :grin: Nowhere near the same though :lipsrsealed:
