Golf mk4
Golf mk4 TDI
Wazzzer
ESP Light on & Shuddering?
Topic: ESP Light on & Shuddering? (Read 3177 times)
gashair
Just got here
07 February 2010, 16:02 »
Hi all, I was driving along today, my ESP light came on and the car started shuddering under acceleration. The ESP light has stayed on and everytime I try to accelerate it really shudders quite bad. Also now sat at idle its running rough and sounds like some cylinders are not firing. Its a 1.9TDI model.. Any ideas?!?!
nadlad
Building Surveyor MRICS
Re: ESP Light on & Shuddering?
07 February 2010, 21:55 »
loom to cylinder 1 has failed due to oil corrosion
about 40 quid for the wire dealers
plus 1 hr labour
basically when u drive esp light and shuddering comes on after a while can be temperamental, rough iling , slow accelaration max speed 70
<<<Big Build Thread>>>
gashair
Just got here
08 February 2010, 12:57 »
Oh right, have you had this then?? It is tempremental, it was fine for about 5 mins this morning then did it again. Gave it a few minutes. Turned it off for a few mins, then started it again and run fine for 10 mins. Is that an easy part to replace?
nadlad
10 February 2010, 15:04 »
guarantee u its that part mine was ecaxt same soem times it did it after 2 mins soem times after 2 hrs the core gets soaked in oil and corrodes hence why its temperamanetal, switchign engine on and off makes it reset so its ok for a bit, get it form vw its one hour labour under rocker cover change the wire simple
Golf mk4
Golf mk4 TDI
Wazzzer
