Author Topic: replacement gearbox issuse  (Read 1724 times)
Offline RIPP3Y
« on: 07 February 2010, 13:49 »
HI guys`n gals,
 As mentioned above, a gearbox from a mk2 8v gti has been fitted to a mk1 1.8 clipper and has left us with a problem when selecting either 1st gear and reverse gear.  In order to select 1st gear, the gear stick has to be pushed down first, and then into gear, this is obviously not right. This is the same proceeder as putting the car into reverse gear and is proving very difficult to drive..
 Can someone shed any light on this issue.
  Thanks for any help, Theo
Offline raferackstraw
Re: replacement gearbox issuse
« Reply #1 on: 07 February 2010, 15:32 »
 i think your gear linkage is not adjusted correctly hence having to push down to select first there is a guide on mk1golf.org on how to adjust
secondly you would be also better of in fitting a gear linkage repair kit while your at it.
when i had a recon gearbox fitted i was still getting 2nd gear crunch, 1 new linkage kit later and i have an as new gear shift and as smooth as factory fresh  :wink:
btw pushing down to select reverse is correct
wayne gardner smokes one rothmans too many
500cc 2stroke bad for ya health
Offline RIPP3Y
« Reply #2 on: 07 February 2010, 17:07 »
thank you m8.
I`l take a look at the guide, Btw, do u recall the price for the kit?
Offline RIPP3Y
« Reply #3 on: 07 February 2010, 17:21 »
found a repair kit on e-bay, thx for the help
 :wink:
« Reply #4 on: 07 February 2010, 20:26 »
make sure you get the kit with the link arms included iirc its about 18-25 quid and not the one with just the bushes  :wink:
« Reply #5 on: 09 February 2010, 12:28 »
did you take the MK2 linkage off the gearbox and swap on the MK1 bit?  the L shaped bit with 2 ball ends on
