Author Topic: pre 90/90 spec heater box **Now with part numbers!**  (Read 1368 times)
Offline jamie_pyrite
« on: 06 February 2010, 20:15 »
Hi all, just picked up a replacement heater box from a mk2 to replace my knackered one.. and it's compeltely different! Looks a bit bigger and everything is in different places.
Are pre 90 spec ones different to 90 spec ones or something? My car is a 91 16v.
« Last Edit: 10 February 2010, 20:44 by jamie_pyrite »
Offline hayescappa
  • Nearly there!
Re: pre 90/90 spec heater box... different?
« Reply #1 on: 06 February 2010, 20:38 »
Any pics?
« Reply #2 on: 08 February 2010, 19:13 »
nope I'm afraid. I'm in Sheffield and they're in Durham now! I'll get the part numbers though.
« Reply #3 on: 09 February 2010, 13:11 »
answer is no, they're the same. if its a lot bigger you may have an aircon one?
« Reply #4 on: 10 February 2010, 20:44 »
I have part numbers!
Original: Valeo H04022598X 192 819 355A
One I've bought: 071 819 003 AA.
Any ideas? :)
Offline mattneck(Beavis)
  • Bristol's Own (DJ) Beavis ;-)
Re: pre 90/90 spec heater box **Now with part numbers!**
« Reply #5 on: 11 February 2010, 10:49 »
Doesn't seem to exist as a part number! Any others on't there?
Sig Removed. No Longer Applicable. New Sig? Nah. Not Yet..
Quote
Sharpo says: (16:57:39)
to be honest i dont doubt that half ggti users have a shortcut on their desktop for sharpie's last posts
Offline stupot115
« Reply #6 on: 13 February 2010, 21:35 »
sound like an air con box. the motor on a a/c one mounts vertical, while the normal one mounts horizontal. hope that helps you. if it is a/c, where did you get it because i need to get hold of a compresser. cheers, stu
« Reply #7 on: 15 February 2010, 14:13 »
I might be able to put you in touch with someone that has a full aircon kit. He's just ripped it out of his car while fitting an ABF :)
