Author Topic: Intermittent starting problem  (Read 844 times)
Offline sillygilly
« on: 06 February 2010, 12:43 »
I have a J plate Mkii that sometimes refuses to start. It doesn't turn over or do anything .
I am not sure if it has a loose wire somewhere but sometimes I rummage around it then starts. The battery connection is ok as far as I am aware.
Can anyone help ?
Offline johnson6672
Re: Intermittent starting problem
« Reply #1 on: 06 February 2010, 12:46 »
Possible ignition switch, i guess if you wiggle and play with the key it will start.
MK4 GTI T AGU, REVO Remap, BMC carbon box, Miltek cat back, Forge diverter valve, THS FR3 engine/Gbox mounts, Some random alloys, lowered on coilovers.
192bhp 212lbft torque.
Offline Reasty
  • Alpine white valver.
« Reply #2 on: 06 February 2010, 12:50 »
I had this exact problem and it turned out to be the starter motor was knackered,next time it does it get someone to sit n the car with the key turned then gently tap the starter with a hammer,chances are it'll burst into life. :smiley:
Offline walchy01
« Reply #3 on: 06 February 2010, 13:29 »
Starter motor fault, just changed mine due to exactly the same problem.
