Its probably quite a slow leak, check the crankcase breather is clear as it can make it worse, short term just soak up all the oil with kitchen towel, clean out the plug well and plug cap with carb cleaner or WD40 and it should be good for quite a while before it fills up again. I did a step by step guide on here for the 16v rocker gasket change, back in 2005 I think but it seems to have gone now.
