Author Topic: Number plate light fault- advice req'd  (Read 1106 times)
Offline walchy01
« on: 03 February 2010, 18:51 »
Hi there
My number plate lights are both out, changed bulbs and still not working, fuse ok, anyone know any common problems with these that can offer help or advice.
Thanks
Russ
Offline oakgreengolf
  • CAR FOR SALE PM FOR FURTHER INFO
Re: Number plate light fault- advice req'd
« Reply #1 on: 03 February 2010, 18:55 »
is it getting 12v. possibly a broken wire some where.
Offline bodga
  • F reg GTI 16v
« Reply #2 on: 03 February 2010, 19:04 »
Open your tailgate and left hand side of the left hinge you have a rubber pipe thingy with wires in it. bet one is broke, mine has, the brown wire(negative) i aint soildered it up yet LOL :laugh:
Offline nealey
« Reply #3 on: 03 February 2010, 19:15 »
My mates went in the same place, we also extended the wires slughtly so they werent so stretched
Offline walchy01
« Reply #4 on: 03 February 2010, 20:17 »
Thanks for the advice will check those wires in the tailgate area.
Thanks
Offline walchy01
« Reply #5 on: 05 February 2010, 17:52 »
Hi All
Checked the wires and found the brown one had split away, the thing is, it has dropped back into the roof  area down that little hole about size of a 50P, do i need to take my head lining down to get to the wire to extend it, or is there another route to take to fix the little bleeder???
Thanks
Offline hayescappa
  • Nearly there!
« Reply #6 on: 05 February 2010, 23:23 »
Remove the boot rubber, this will allow you to lower the headlining just enough to get at the wire, awkward though!
Offline walchy01
« Reply #7 on: 06 February 2010, 11:44 »
Thank you, another 10 minute job that will take the morning up!!!!! :sick:
Offline nealey
« Reply #8 on: 06 February 2010, 19:01 »
Dont need to take the headlining down, take the trim down that runs along the back, take the ns parcel shelf trim out and the c pillar trim and you should be able to find it, it will be awkward though
