Author Topic: Full beem I think is shorting out??  (Read 1250 times)
Offline MK4_20VT
« on: 31 October 2004, 15:36 »
Had to use my full beam the other day & drivers side didn't light up properly.  The passenger side light & spot lights up ok, but the drivers side spot will not come & and drivers side main beam goes out & in left with diped.  Also the dashboard doesn't light up with the Blue LED when the full beam is on?
Could this be a faulty light switch???
Offline JMallows
Re: Full beem I think is shorting out??
« Reply #1 on: 31 October 2004, 18:51 »
Thats probably the fuse...? If i remember rightly, you have two fuses, high left and high right/high warning LED. That would explain your situation perfectly!!
A clever person solves a problem. A wise person avoids it.
Offline MK4_20VT
« Reply #2 on: 31 October 2004, 20:10 »
Balls! I checked eveything but the fuse's, well I have been in work since 6am  ;D
Thanx bud, will check tomorrow
Offline MK4_20VT
« Reply #3 on: 31 October 2004, 20:29 »
Just been out & fixed the prob.  Big thanx to jmallows, the fuse had not blown, the connection to the fuse was loose, so I sorted that & bingo full beam again  ;D
Offline JMallows
« Reply #4 on: 01 November 2004, 14:51 »
Glad i helped ;D
