Author Topic: GTI Idle  (Read 7270 times)
Offline adw555
GTI Idle
« on: 03 February 2010, 10:45 »
Anyone with a GTI mk 6 ever find that when you come to a reasonably abrubt stop, the engine idle sits higher than normal?..between 1100 and 1400 sometimes..
Offline keelaw
  • It's here!
Re: GTI Idle
« Reply #1 on: 03 February 2010, 13:43 »
DSG or manual?
If manual, was the clutch up when you stopped?  Otherwise idle = nil  :evil:
Mk6 Golf GTI 5dr, DBP, Monza Shadow, Xenons, ACC, RCD510, Park Assist, Camera, Lux pack.... and now bluetooth.... and now DSG!
Offline adw555
Re: GTI Idle
« Reply #2 on: 03 February 2010, 14:19 »
it's a manual....I've noticed on two GTIs now....strange  :sad:
Offline funkythumbs42
Re: GTI Idle
« Reply #3 on: 03 February 2010, 14:31 »
when i first turn over my mkv gti it sits a bit higher normally at around 1500 revs and then settles down to just below after around 10 mins of driving
Offline AlanD
  • MK5 2.0T 16v
Re: GTI Idle
« Reply #4 on: 03 February 2010, 14:37 »
ALL cars do that, its like the old chokes, warms the engine up ;)
Online Snoopy
  • Moderator
  • Geoff.
Re: GTI Idle
« Reply #5 on: 03 February 2010, 18:28 »
Also it maybe you have the aircon on try it off as the pump can demand the revs higher for a short time.
Current Garage:
35+ years of GTI ownership.
Offline adw555
Re: GTI Idle
« Reply #6 on: 03 February 2010, 21:21 »
it does it intermittently when both hot and cold. A quick blip of the throttle brings the idle back down to normal. Very annoying and can't seem to find a pattern to it. Have had this on two mk6 GTIs now..
Offline ub7rm
Re: GTI Idle
« Reply #7 on: 03 February 2010, 22:06 »
Didn't someone on this forum eventually reject their car because of this issue?  If not it was something similar ...  VW couldn't find the fault despite much investigation  :rolleyes:
2020 BMW 128ti
2017 Golf GTD Estate
Offline DDRFan
Re: GTI Idle
« Reply #8 on: 04 February 2010, 01:45 »
I believe it is Mr OP himself who had this issue
Offline adw555
Re: GTI Idle
« Reply #9 on: 04 February 2010, 14:21 »
yip...first one was rejected as after 6months problem was still there and despite it logging errors about 'eratic idle' and the dealer changing the throttle body + other parts....the new car arrived this week and has done it once last night..pulled into the drive and car was idling at 1400 rpm..when fully warm. A quick blip of the throttle dropped the revs back down to normal....can't believe it!
