Author Topic: HELP- Replacing rear axle/sub frame bushers knackered  (Read 1534 times)
Offline walchy01
« on: 02 February 2010, 19:10 »
Hi all
My Gti has failed it's mot on the rear sub frame rubber bushes both sides, :cry:, i have been told that this is a real git of a job, someone has advised me to replace the whole axle in order to make the job a little easier to whoever offers to do the job at the right money and obviously i can treat/spray the axle prior to taking it for fitting.
Has anyone had this job done?
What sort of money will it cost?
How long a job is it?
Thanks for you help in advance, much appreciated.
Walchy01
Offline johnson6672
Re: HELP- Replacing rear axle/sub frame bushers knackered
« Reply #1 on: 02 February 2010, 19:27 »
Its not that bad a job if you are mechanically minded, butthe bushes are a mear to get out, job takes a couple of hours+ depending on how much of a mear it wants to be, extraset of hands helps for refitting aswell.
Where are you?
MK4 GTI T AGU, REVO Remap, BMC carbon box, Miltek cat back, Forge diverter valve, THS FR3 engine/Gbox mounts, Some random alloys, lowered on coilovers.
192bhp 212lbft torque.
Offline oakgreengolf
  • CAR FOR SALE PM FOR FURTHER INFO
« Reply #2 on: 02 February 2010, 19:33 »
The standard bushes are suppost to be a pig to do, however you can get the aftermarket type that come in two halfs.
Offline walchy01
« Reply #3 on: 02 February 2010, 19:42 »
I'm in Sunny Sheffield. :cool:
Thanks for the advice.
Offline johnson6672
« Reply #4 on: 02 February 2010, 19:46 »
If you was any closer i would say i would do it for some beer tokens but up north.
Offline walchy01
« Reply #5 on: 02 February 2010, 20:05 »
Shame your not a bit closer would have been happy to give you some beer tokens to do the job.
Thanks
Offline walchy01
« Reply #6 on: 02 February 2010, 20:09 »
Been offered powder coated axle with refurbed discs and calipers for £180, what does that sound like on price???
Thanks
Offline hayescappa
  • Nearly there!
« Reply #7 on: 02 February 2010, 21:11 »
Sounds good, when you think what two calipers cost, you still have to fit though.
Are your calipers knackered, fitted mk4 items to mine.
The bushes are tricky enough to remove, and if you want to reinstate the VW type and not Poly bushes you will require some tools.
For removal, I always burst out the middle rubber part of the bush and than use a hack saw to cut out the bush (remove blade from hacksaw and put through hole and reconnect to hacksaw, upside down and cut away).  Be careful not to cut in too much into the axle.  The blade usually sticks when you have cut through the bush.  Beat out with hammer.
Also note the position of the old bush prior to removing, as if you are installing the VW type it will have to go back the same.  Polys dont matter.
You will need a hydrualic porta power to push in the bushes in location if using VW ones, polys are easy to install.
Once reinstated, make sure your lower the car, prior to tightening the main bush bolt.
