Author Topic: Miss fire/ funny stutter  (Read 3897 times)
Offline Max
« on: 28 October 2004, 10:41 »
Hi,
I have a problem with my mk3 Gti 2.0 8 valve: When I'm on the motorway (and pretty much anywhere else when I can get over 50 mph) and I'm on part throttle (not quite on the over-run, not accelerating, just cruising really) the car seems to stutter. All of a sudden for a split second it's as if the engine cuts out and you get a jolt through the car and then it's fine again. It doesn't seem to do it when accelerating or braking and it doesn't do it when cold. The gauges don't die and the stutter is really quick, over in a flash. It doesn't feel like a fuel problem i.e. no loss in power (apart from during the split second), no missing or popping - but obviously I can't be sure.
I've replaced the plugs and coil and fairly recently the water temp sensor, before I spend more cash on the leads, cap and rotor arms does anybody have and ideas as to what could be causing the problem?
All suggestions gratefully received!!
Offline Len
Re: Miss fire/ funny stutter
« Reply #1 on: 28 October 2004, 10:03 »
Mate you got the Mk 3 disease!
Its the relays! Either the fuel pump or ECU relays or both.
Loads of threads around about this problem.
www.sas.org.uk
www.the-ace.org.uk
Offline Justins145bhpMK1
« Reply #2 on: 28 October 2004, 10:41 »
Sounds like the same prob I have, ive dome all the relacement relays, dizzt ht's plugs, rotor arm, coil etc and itys still douing it.
Lambda sensor next.. ill let you know how I get on.
Offline Max
« Reply #3 on: 28 October 2004, 12:58 »
Thanks guys, I've done a quick searck on German & Swedish's site and they only list a fuel pump relay - can you recommend a source for the ECU relay?
Stupid question now, I don't suppose you know what numbers they are? It'll make it a lot easier for me to swap them!!
« Last Edit: 28 October 2004, 13:46 by Max »
Offline adyh
« Reply #4 on: 28 October 2004, 12:12 »
Try VW ?
« Reply #5 on: 28 October 2004, 12:16 »
Ive got a spare ECU relay should you want it??
Offline Max
« Reply #6 on: 28 October 2004, 13:33 »
That's very kind of you thanks but my local dealer has one in stock for 8 quid so as I'm fed up with the stutter I'll go for that one.
Many thanks again though  :) :)
Offline jo
  • im not as think as you confused i am
« Reply #7 on: 03 November 2004, 21:06 »
had the same prob..and it only got worse, i checked relays, changed spark plugs new rotor arm, dizzy cap ht leads..and it still did it. have just had to get a new starter motor..and it fine now..might not be the solution, but its worked for me :D
97 mk3 gti
"praise the lowered"
Offline knobby
« Reply #8 on: 15 January 2005, 15:52 »
Ive got the same problem.... Changed the coil, plugs, leads and dist cap, and both relays and still it happens... Really bugging me now... HELP!
Old VW's never die...they just go faster!
Offline Resevoirfrogs
« Reply #9 on: 20 January 2005, 13:19 »
Mine started 3 weeks ago with the same problem. Took it to my local Vdub specialist and ran a diagnostic but found nothing. Changed the plugs, dizzy and crank impulse sensor and still it gets the jitters! Got the fuel pump and ecu relays today. I'll let you know how i got on. Spent ?290 so far on pi55ing myself off! I read on another link that taking the ecu fuse out may help as it apparently resets the ecu?! Might be worth a try???
