Author Topic: Re-timing the 2.0L GL (New Owner)  (Read 1944 times)
Offline Ownage1100
« on: 28 January 2010, 23:41 »
I am not sure if this is the right forum, but it is the closest thing I could find. There is almost no volkswagen information online.
Anyway I just bought a 1996 Golf GL. The car does not start. Here are a few random questions:
1) What is the firing order on a Golf GL 2.0?
2) Are the only timing marks on the Golf on the camshaft and the flywheel?? Are there no marks on the crank pulley gear (like on a Honda or almsot any other car)
3) I am able to rotate the distributor body by hand. What is the correct position for the distributor body?
I'm basically trying to check\retime the motor. Please help or direct me to a site that can help.so I can get her running.
Offline Ownage1100
Re: Re-timing the 2.0L GL (New Owner)
« Reply #1 on: 29 January 2010, 05:43 »
I'm American.  We have the sh!tty versions of cars here :(.  I guess I can't find any help here lol
« Reply #2 on: 29 January 2010, 10:14 »
An engine code my or will help.
Offline javalin
« Reply #3 on: 29 January 2010, 10:34 »
For the British 1.8GL (ABS Engine) the answers are as follows - suggest they'll be similar for yours, but a Bentleys or Haynes manual should be consulted
1-3-4-2
The two marks to care about are the cam pully and the flywheel - behind the green plastic screw cover on the top of the gearbox.  The crank mark seems a little vague for timing work - you'll end up being 1/2 tooth or more out.
ABS engine is 5 deg BTDC from memory - you'll need a VAG-COM or other diagnostic interface to put the ECU into "timing mode" so the car doesn't try to adjust - then a advance timing light to do the change.  Other engine's have different timing requirements - i.e. the 2L GTI AGG engine is 5-15' BTDC.
Best check the books, or get a garage to help
James
You only ever need two tools in life. If it moves and it shouldn't use Duct Tape. If it does not move and it should, use WD40.
Offline axewielder
  • 95 dragon 8v
« Reply #4 on: 29 January 2010, 12:15 »
could just ask on vortex as they will most likely know being american and all  :drool:
« Reply #5 on: 29 January 2010, 12:31 »
this is likely to be the 2.0 crossflow lump, afaik no US models got the counterflow 2.0 like we have.  there is a crank timing mark, rotate it around and you'll see a notch. this lines up to an arrow on the timing belt cover. But with the bottom end timing, I'd not use crank pulley at all, I would use the flywheel mark instead. you have to unscrew the cover cap from the top of the gearbox near the block, its a 27mm hex socket. I just tap em round with a hammer.
the cam also has a mark, there should be a notch on the outside face that lines up to an arrow on the cambelt cover. with the dizzy,m the rotor arm should be lined up to the thin groove on the dizzy housing.  I beleive this engien has a crank sensor, if so you line the dizzy to the notch and leave it there. if it does not you need to use a timing gun, but I'm not 100% sure of the setup procedure. as above, vortex best place to check this out.  The crank sensor will be right at the bottom of the block, gearbox side. its under the oil filter housing/front engine mount.
Offline javalin
« Reply #6 on: 29 January 2010, 13:15 »
water pump pliers do less damage!
« Reply #7 on: 29 January 2010, 13:24 »
not much room for that though
