Author Topic: torque settings  (Read 792 times)
Offline rachsgolf
torque settings
« on: 28 January 2010, 22:08 »
hello, could someone tell me the torque settings for the main hub nut in the center of the wheel and also for the strut top nut that is tigtened up from under the bonnet.
cheers andy...
Offline daytona
Re: torque settings
« Reply #1 on: 28 January 2010, 22:23 »
top suspension strut nut is 60nm/44lbf.The middle nut depends on the model,if early gti thenits in 2 stages,1st is to 90nm/66lbf then turn another 45degrees...but if later model the 1st stage is to 200nm/150lbf then fully slacken the nut then tighten 50nm/37lbf then another 30 degree angle(according to haynes)
if in doubt,rev the arse out of it
Offline rachsgolf
Re: torque settings
« Reply #2 on: 28 January 2010, 23:11 »
hi, its a 1996 2.0 16v so which catagory does that fit in? Cheers.
Offline AudiA8Quattro
Re: torque settings
« Reply #3 on: 29 January 2010, 00:18 »
According to Elsa, its 90nm + 45 degree turn.
