Author Topic: Engine Codes  (Read 1160 times)
Offline robertb2700
Engine Codes
« on: 28 January 2010, 17:12 »
This is pretty bad to be asking but I'm buying new spark plugs and obvioulsy I need to know the engine code for this(so I don't buy the wrong ones) but I can't figure out what engine code I have, I can't see it anywhere on the engine block. I've got an 'M' plate 1.8 driver. Can anyone tell me what engine code I have?
Thanks in advance  :smiley:
Rogue trader - pm's disabled - robertb2700@live.co.uk
Re: Engine Codes
« Reply #1 on: 28 January 2010, 17:37 »
have alook at the sticker in the boot, there are a few 1.8 codes over the years
Offline robertb2700
Re: Engine Codes
« Reply #2 on: 28 January 2010, 17:39 »
Where abouts in the boot is the sticker?
Offline ace
Re: Engine Codes
« Reply #3 on: 28 January 2010, 18:38 »
lift the carpet up it should be under there
Offline robertb2700
Re: Engine Codes
« Reply #4 on: 28 January 2010, 19:37 »
Thanks :) been told to look on the timing belt cover so I will try both tomorrow once it's light again.
Offline javalin
Re: Engine Codes
« Reply #5 on: 29 January 2010, 10:36 »
yup its also on the top of the original timing belt covers.
You only ever need two tools in life. If it moves and it shouldn't use Duct Tape. If it does not move and it should, use WD40.
Offline axewielder
  • 95 dragon 8v
Re: Engine Codes
« Reply #6 on: 29 January 2010, 12:12 »
i just found out last night its also on my V5/logbook under engine number, not sure if all have it, was something like ADY2309402394?
Re: Engine Codes
« Reply #7 on: 29 January 2010, 12:32 »
if you have the service book yeah a copy of the boot sticker is stuck on the inside cover :)
