Author Topic: Replacement headlight BULBS  (Read 1159 times)
Offline naturn007
« on: 27 January 2010, 19:30 »
Hi,
Can anyone advise on brighter headlight bulbs for my mk3 GTi.  I don't want to replace the entire setup i.e hella twins.  I just want brighter bulbs.
Any idea's people.
Many thanks
Offline boneybradley
  • Back in a Mk3...
Re: Replacement headlight BULBS
« Reply #1 on: 27 January 2010, 19:35 »
philips/osram/ring are all decent brands and I use philips power 5000k bulbs myself and can't fault them, just remember the higher the k rating the brighter the light and you need h1 bulbs for the gti :wink:
edit: factory hid's are 4000-4300k and std bulbs are closer to 3200
« Last Edit: 27 January 2010, 20:03 by boneybradley »
Offline naturn007
« Reply #2 on: 27 January 2010, 19:37 »
philips/osram/ring are all decent brands and I use philips power 5000k bulbs myself and can't fault them, just remember the higher the k rating the whiter (and brighter) the light and you need h1 bulbs for the gti :wink:
Many thanks, I will have a look for those then. :cool:
Offline christomk3gti
« Reply #3 on: 27 January 2010, 19:38 »
good to no. coz i would like mine brighter aswell..
cheers
Black 8v GTI............. Whats a Waffle Valve?
Offline flash-derby
« Reply #4 on: 27 January 2010, 21:14 »
http://cgi.ebay.co.uk/2x-H1-White-Car-Auto-Lighting-Headlight-Light-Bulb-Lamp_W0QQitemZ260536227845QQcmdZViewItemQQptZUK_CarsParts_Vehicles_CarParts_SM?hash=item3ca92b5805
i've orderd  a set of these as the full beam for mine (got HIDs in main) used to run the H7 versions of em in my vectra made it loads better.
HTH
if its got pistons or tits, either way its gonna be expensive
