Author Topic: hellp needed ,,,,,,, i am in somerset  (Read 949 times)
Offline petenofear
« on: 26 January 2010, 21:43 »
hiya all
i am in some need with my brakes on my mk4 turbo
the car had a smash about 8 mth ago
now all done and ready for mot BUT
i cant get the brakes to bleed up i have tryed and tryed
when car is NOT running the brakes r fine
when car is running the pedel gose to the floor but pump it and its fine till u let of and then to the floor again
been told in may be air in the abs ,,but i am lost with all this
is there any one local to me that can help thanks pete
just out side yeovil somerset
Re: hellp needed ,,,,,,, i am in somerset
« Reply #1 on: 27 January 2010, 00:10 »
Could be a faulty master cylinder.
« Reply #2 on: 27 January 2010, 08:37 »
what car is it, some abs systems need to be switched to a special mode using vag-com so you can bleed them up properly. could be bias valve wasnt opened if fitted, you clamp it open with mole grips so as to provide full braking force to the rear
