Author Topic: Replacing Cam Belt?  (Read 2241 times)
Offline Nokesie
Replacing Cam Belt?
« on: 26 October 2004, 21:57 »
My Gti Turbo has done 69000 miles and has full service history but i dont think it has had a cambelt, can anyone tell me when i should think about getting it replaced, its a w reg by the way. Any advice would be great.
Dan
Offline Gozza
Re: Replacing Cam Belt?
« Reply #1 on: 21 December 2009, 19:59 »
Just came across this as I am in a similar situation, I would say now as VW say every 4 years of 40k miles.
If it has any cracks in the belt at all get it done asap and ideally dont drive it or start it at all.
Offline roger1234
« Reply #2 on: 21 December 2009, 20:45 »
Dan
[/quote
I agree indeed you have pushed your luck already, change it now before the unthinkable happens.
« Reply #3 on: 22 December 2009, 00:27 »
As already posted get it replaced asap.
Offline ub7rm
« Reply #4 on: 02 January 2010, 07:22 »
Get your water pump changed at the same time.  Part is £30 or so and shouldn't be any extra labour.  They have a habit of failing right after changing the cam belt which means having to stip it all down again.
When I had my 1.8T I changed it at about your mileage (when I bought it) for my own piece of mind.  Think the book says the service interval is 120k miles for your model (check) but 60k / 5 years is more sensible.
2020 BMW 128ti
2017 Golf GTD Estate
Offline Gozza
« Reply #5 on: 02 January 2010, 10:36 »
Apparently the 1.8T is 40k miles and the TDI 60k miles for cambelts.
Also be aware the waterpump should be replaced with a water pump with metal fins.
Mine is going in Monday for a Cambelt kit, metal waterpump and oil service. £300  :sad:, but at least its all done I guess.
Offline Neo Badness
  • Feet are for pedals
« Reply #6 on: 02 January 2010, 21:48 »
Yikes! 300? I need this done too on my mk2 valver.  :sad:
Recommend getting the metal immpeller waterpump as I took the old waterpump with plastic bits off my mates mk3 and it was proper fooked :grin:
