Author Topic: radio booster thingy  (Read 1731 times)
Offline vdubnut
« on: 25 January 2010, 12:48 »
Hi all
Trying to improve the recption on my radio...... bought a booster of ebay....which cable do you conect the blue wire from the booster to... If it helps.... to get the radio to work i had to have the red and yellow wires connected to the live feed as it needs a perm live....any help appriciated!!
Andy
Re: radio booster thingy
« Reply #1 on: 25 January 2010, 13:11 »
Blue wire would be the electric aerial feed wire on the head unit.
Offline vdubnut
« Reply #2 on: 25 January 2010, 13:36 »
cheers wayne....just tried that and as soon as i connect the wire reception gets worse LOL!! looking more and more like ill ahve to bite the bullet and change the wing ariel..... :laugh: any ideas if its easy to run the new ariel?
« Reply #3 on: 25 January 2010, 14:08 »
Easy enough to do, just remove the arch liner.
Offline FOREST GREEN
« Reply #4 on: 25 January 2010, 14:27 »
I attached mine to the red positive, it works a treat now, even in the lock up!!
Offline vdubnut
« Reply #5 on: 25 January 2010, 14:50 »
lol think im cursed....tried on red same made its worse!......
do you need to take out the whole cable or is there a connecter under the arch
Offline harlemex
« Reply #6 on: 25 January 2010, 15:17 »
I have had the same prob. I tried every wire i could find and it just made the reception worse. I have a roof mounted aerial and it appears to be wired ok, but I would say it doesnt work at all. When i do get reception, it is just being  recieved by the stereo itself and not the aerial. ie the roof aerial does nothing at all. :sick:
Offline Mikester
  • Civic Type R
« Reply #7 on: 25 January 2010, 15:19 »
I found my radio rubbish with or without booster. Its a mk3 thing...
Offline Shady Pioneer
  • graphic designer.
« Reply #8 on: 25 January 2010, 15:51 »
+1 Just stick to CDs or your iPod, 2000+ tracks on random will see you through for weeks lol!
Offline GuessWho
« Reply #9 on: 25 January 2010, 17:07 »
The radi that came with the car wasn't bad at all, when I put a new one in the ISO had to be taken out and a new one fitted, it was then sh!t.
The old ISO had a little box on the orange wire, I put that on and it was better!
