Author Topic: Drivers door doesn't always open after pressing key fob  (Read 1133 times)
Offline starlingadey
Anybody else ever experienced this? Doesn't happen everytime. Locks ok and opens passenger door/doors (if pressed twice...5 door)
Offline BuckieGTI
Re: Drivers door doesn't always open after pressing key fob
« Reply #1 on: 25 January 2010, 09:51 »
Yours is probably set up the way mine was. 1 push only opens drivers door and 2 opens them all. This can be switched off using the vagcom. I got mine removed after getting annoyed with it.
« Reply #2 on: 25 January 2010, 09:54 »
Meant to say...thought it might've been the fob but sometimes door doesn't open even when pressing the interior button for locking/ unlocking???
Offline FamilyDub
« Reply #3 on: 25 January 2010, 10:16 »
You can change the lights/locks/etc settings in the MFD.
MKV GTI | Reflex Silver | 5-dr | Anthracite 17" | Manual | Highline MFD | Cruise | Revision 'D' DV | Dirty Pipes |
The GTD is like a blow up doll. The GTI is like a proper woman. Sure the doll might last longer, and the woman might have higher running costs, but which would you rather have?
Offline _Adam_
« Reply #4 on: 25 January 2010, 11:05 »
i've had this ongoing problem for ages now. VW say there is a wiring issue somewhere towards the battery/fusebox end, and they will have to trace back from the lock mechanism to find it. £80 an hour till they do.
do your wingmirror/siderepeater/LED door light still work? mine have all gone dead. no power to door except the window.
