Author Topic: Common Part numbers .....post yours here  (Read 4427 times)
Offline boneybradley
  • Back in a Mk3...
« on: 24 January 2010, 18:47 »
Well I am going to build a thread of the common mk3 part number's... So I need your help and we hopefully will have a decent list (to save ££) with soon?
I will start
Engine
ECU Relay no30 part is: 165 906 381
Fuel pump relay no167 is: 191 906 383
Crank angle sensor (also known as engine speed sensor) is: 037 906 433 and is the same for 8 or 16v cars
Body
Rubber sill trim (the cover with the metal insert) £25.18 per side
Left passenger side is: 1H0853985B41
Right drivers side is: 1H0853986B41
« Last Edit: 24 January 2010, 20:39 by boneybradley »
Offline zdebx
Re: Common Part numbers .....post yours here
« Reply #1 on: 24 January 2010, 20:37 »
Fuel pump relay no167 - 191 906 383
My Golf mk3 1.8 SE is FOR SALE - Jetex exhaust + Jamex coilies & More...Only £550! More info here > http://www.golfgtiforum.co.uk/index.php?topic=161711.0
Offline javalin
« Last Edit: 12 April 2011, 19:31 by javalin »
You only ever need two tools in life. If it moves and it shouldn't use Duct Tape. If it does not move and it should, use WD40.
