Author Topic: Hella's + HID  (Read 5455 times)
Offline zdebx
Hella's + HID
« on: 24 January 2010, 16:47 »
I'm sure those of you, who's got Hella headlights and HID will know this problem.
When the lights are on dipped beam, HID works perfectly. Also when you switch the full beam on, HID is still there.
However, when you try to switch the sidelights on, HIDs start to flash really fast, and eventually just switch off. So what's the problem here and how to get it fixed?  :shocked:
My Golf mk3 1.8 SE is FOR SALE - Jetex exhaust + Jamex coilies & More...Only £550! More info here > http://www.golfgtiforum.co.uk/index.php?topic=161711.0
Offline VR6-Joe
Re: Hella's + HID
« Reply #1 on: 24 January 2010, 16:52 »
That's because you have the dayglo resister that everyone has been talking about lately on the forum.
The HID's need 12v to work, but normal headlight bulbs don't. Therefore the HID's are tricked into thinking the battery is flat as they aren't being provided enough power, hence why they flicker and switch off.
There's three ways around this:
1. Throw your HID kit in the bin
2. Unplug the yellow plug located behind/underneath your airbox
3. Buy a seperate wiring kit off ebay that will cost you an extra £10-£15
I chose option 2 :)
Gone but not forgotten;
1983 Mk1 Golf GX - 1991 Mk2 Golf GTI - 1988 Scirocco Scala - 1989 Mk2 Golf CL - 1993 Mk3 Golf Ryder - 1996 Mk3 Golf SE - 1996 Mk3 Golf CL - 1995 Mk3 Golf GTI 16v - 1996 Mk3 Golf VR6 Highline - 2003 Saxo VTR - 1996 Mk3 Golf VR6
Offline zdebx
Re: Hella's + HID
« Reply #2 on: 24 January 2010, 17:05 »
I chose option 2 :)
Is that the plug, which is between the top and bottom air pipes? Tried disconnecting it, but made no difference. They still flash like crazy.
Stupid question, but I forgot.....When the sidelights are on, the middle lenses suppose to light up or the outer ones, but just really dipped?
Offline whiter_than_white
  • Seize the day or die regretting the time you lost!
Re: Hella's + HID
« Reply #3 on: 24 January 2010, 17:06 »
do you have a pic of what needs disconnecting??
Offline Shady Pioneer
  • graphic designer.
Re: Hella's + HID
« Reply #4 on: 24 January 2010, 17:15 »
Get a relay kit, that's your best bet, that's what I did, mind you I got Adam to fit it because I'm useless lol!
kells
Re: Hella's + HID
« Reply #5 on: 24 January 2010, 17:31 »
mine did this, use a relay, cost pence!
i also wired mine direct to my headlight switch using thicj cable, a inline fuse and a relay
so now this is how mt switch works
FIRST CLICK  - INNER SIDELIGHTS COME ON
SECOND TWIST OF SWITCH - HIDS COME ON AND INNER SIDELIGHTS STAY ON
CLICK BACK TO POSITION 1 OF SWITCH - HIDS GO OUT AND INNER SIDELIGHTS STAY ON
Before i did this on the first click 1 side hid would come on or flicjer, and to get both hids to come on i had to turn lights off and switch straight to position 2..
hids need more power to fire up, a relay worked for me, and the added benefit of thicker wire direct to the headlight switch was even better (u must use a fuse tho too)
OH ONE OTHER THING POLICE PULLED ME (NOT FOR MY HIDS)
I asked the copper if they were a issue - guess what, NO  he thought they were what came with my car, was gonna make aseperate post but didnt bother on this forum as its full of haters so no point :grin:
this happened at 6.30am this morning annd it was the traffic police that stopped me
« Last Edit: 24 January 2010, 17:33 by kells »
  • graphic designer.
Re: Hella's + HID
« Reply #6 on: 24 January 2010, 17:33 »
When I have the first click my HIDs and inner sidelights are both on fine, turn to the second click and they remain the same.  :smiley:
kells
Re: Hella's + HID
« Reply #7 on: 24 January 2010, 17:35 »
**edit, thats wrong, first click should be side lights only NOT hids
  • graphic designer.
Re: Hella's + HID
« Reply #8 on: 24 January 2010, 17:39 »
Not mine.  :smug: I'm using a relay kit, but there doesn't seem to be any problems with it.
Offline zdebx
Hella's HID Part 2
« Reply #9 on: 24 January 2010, 20:35 »
Ok, first of all. What's the dayglo resistor everyone's talking about? Is it the plug, which is between the top air pipe and bottom one (hot air)?
I tried to remove it, but made no difference to the lights. They still flash, when the switch is in the middle.
As I previously asked, what are the sidelights on Hella's? Are they the middle lenses or the outer ones, but dipped (not fully dipped)?
And this relay...Where do I get that and what is it called?
« Last Edit: 24 January 2010, 20:50 by boneybradley »
