Author Topic: GOLF AEX 1.4 HELP  (Read 1702 times)
Offline vwnutant
  • dubbin since 1990
GOLF AEX 1.4 HELP
« on: 22 January 2010, 17:26 »
Need some help/advice....
ive just bought the mrs one ...
and this below problem seems the same as ours- ive bought new thermostat/rocker gasket/plugs/leads/oil filter/oil/ etc for a service , i was hoping it may be the thermostat!?...got all new coolant and gona give that a flush...heaters work fine
2.the temperature needle drops to zero when i drive and goes to 90degrees when stationary,ive changed temp sensor and thermostat but stil the same
this problem is the same with ours , and same engine code ...? any ideas ....
ant
SORTED THE TEMP NEEEDLE GOIN UP AND DOWN SEE BELOW UPDATE
Re: Raw unburn fuel smell,need urgent help! golf mk3 1.4
Postby vwnutant on 22 Jan 2010 05:22 pm
right went to gsf today got the other sensor
changed the one on the radiator and changed the one under the dizzy ....
cleaned the water out again a bit...topped it up...started the car and it now comes up and down temp wise ok....
thought i would just take it for a spin .....BUT it now wont start ???? it keeps trying but just wont start????? :twisted: anyone got any ideas.......
ive changed
plugs
leads
rotor arm
rad sensor
sensor under dizzy
flushed water out cleaned
checked oil level- ok (not changed yet)
rocker gasket
its got a pretty new battery on it
dont think its the battery as none of the clocks on the dosh reset or die ....it just keeps trying to start but wont??....
anyone close handy with cars??? Mrs has now been without a car for a month?....need to get this sorted or give up if i know what it is...
ant
====VWNUTANT====
===ADMIN AT UKPASSATS===
MK3 GOLF FOR THE MRS ........1.4C
Offline BobProperty
Re: GOLF AEX 1.4 HELP
« Reply #1 on: 23 January 2010, 08:56 »
Define "trying to start". If it fires then dies almost immediately that sounds like an immobiliser problem. If it keeps turning over but not firing (I'm guessing it's that option) then check carefully that you have put the HT leads on the distributor correctly. Firing order is 1342 (but you knew that   :smiley: ) and rotor turns anti-clockwise as you look on the top of the distributor. So the distributor should be positioned something like:
24
13
Owner of fleet of Mk3 Golfs. Not sure why.
Offline vwnutant
  • dubbin since 1990
« Reply #2 on: 23 January 2010, 14:40 »
all leads/plugs are all in okay....
it may of got damp when i topped up/emptied the washer bottle all over the place/coolant etc lol?...as it started first time today ...so will take it for a drive and see if it does it again ...
if a car has been driven for a while with the temp gauge not working and the car hasnt been getting up to heat properly due to thermostat or the other sensors not working , and then you fix this so the temp gauge is okay and the water etc is flowing around the engine now would this of done the engine any harm at all?...the water in the coolant bottle is a horrible colour ...orange really orange....i will need to take the bottom pipe off and flush it through again will i ?....is this the best pipe to take off the radiator to flush it
cheers
ant
====VWNUTANT====
