I have just looked through my logs of ECU repairs with this fault code, ON EVERY TFSi engine that I have seen this code, it has been a mapped ECU.
The dealers can erase this code, and then reflash the ECU with the latest software version, it may not work, however according to the info I have here this may not always delete the fault code permanently.
If all else fails and you fancy a drive to sunny Newcastle, I am confident that this issue can be solved via software work and not a new ECU. PM me if you need any impartial advice.
