Author Topic: Gear stick revolves 360 degrees....  (Read 890 times)
Offline Skiing
« on: 22 January 2010, 13:49 »
Yup, it used to turn a bit, but now I can turn the stick completely through 360 degrees (the reverse gate thing turns as well as part of the stick) what can I tighten up to prevent this - or do I have to replace the mechanism (think its the de-dent cup thing) which sits below? Is it the pinch bolt (and where is this incidently) Any ideas would be great.
1988 Golf GTi Mk2 16v 2.0 9a bottom end- Oak Green - 3 door - full black factory leather...
Re: Gear stick revolves 360 degrees....
« Reply #1 on: 22 January 2010, 14:53 »
gotta change the cup and ball at the bottom of the stick, what prevents it from spinning is a pair of lugs on the ball which lock into slots in the housing
Offline Skiing
« Reply #2 on: 22 January 2010, 15:17 »
a-ha - well I will get it ordered - I know its a bugger to change though... will get it dont at next service methinks... Thank-you
Offline gavL
« Reply #3 on: 22 January 2010, 15:53 »
It's not that difficult to do if you follow the guide it all fine.
| DubNorthEast |
