Author Topic: Engine Photo of 16V engine Showing throttle body, MAF etc  (Read 2714 times)
Offline Newitt
Hi does anyone  Have a photo of a 2.0L 16V GTI Engine showing whats, what, throttle body, MAF thingy etc
Thanks
Offline zdebx
My Golf mk3 1.8 SE is FOR SALE - Jetex exhaust + Jamex coilies & More...Only £550! More info here > http://www.golfgtiforum.co.uk/index.php?topic=161711.0
Offline Newitt
Re: Engine Photo of 16V engine Showing throttle body, MAF etc
« Reply #2 on: 21 January 2010, 21:35 »
Cheers but looks completly different, DOHC stamped on the manifold etc.
I'll have a closer look
thanks again
Offline gazpowells
« Reply #3 on: 21 January 2010, 22:14 »
that photo in link is the 8v engine not 16v
16v looks like this
what info you after mate?  :smiley:
Offline Newitt
« Reply #4 on: 21 January 2010, 22:25 »
That's the one Pal. having idiling problems so was going to clean the throttle body and MAF as mentioned in a few  of the threads, also check the oil pipes etc  , just bought the haynes manual doesnt really tell me what i want to know
Offline DazVR6
  • mk3 VR6...FEEL THE GRUNT.
« Reply #5 on: 21 January 2010, 22:31 »
Hope that helps.....
Throttle body is just where the black plastic inlet pipe meets the manifold, there is no maf on a 16v engine, just a map sensor which is located in the ecu and works via that blue vac pipe that runs from the top of the manifold to the ecu.
That black square box at the bottom of the pic is the pcv valve which is part of the engine breather system....hope that helps. :smiley:
Offline Newitt
« Reply #6 on: 21 January 2010, 22:34 »
Thanks thats great, i'll have a look at the weekend.
Offline Newitt
« Reply #7 on: 21 January 2010, 22:38 »
Looking the picture, the small bore blue pipe on the back of the manifold, i've (the garage) had to disconnet it to get the car to run, if i reconnect the car stalls, any ideas?????
Offline DazVR6
« Reply #8 on: 21 January 2010, 22:43 »
That blue pipe that runs from the back of the manifold is for the map sensor in the ecu, if disconnected or damaged it should/would cause running issues/ stalling, the map sensor calculates the amount of air drawn into the engine at any given time which allows the ecu to dump in the correct amount of fuel.
Offline gazpowells
« Reply #9 on: 21 January 2010, 22:45 »
the blue pipe in the picture is the vacuum pipe for the ECU map sensor
if this is disconnected then engine will run rough
