Author Topic: door  (Read 1396 times)
Offline VR6_ROB
  • Mk2 VR6 / Corrado G60
door
« on: 24 October 2004, 23:24 »
how do i straighten my door as it has dropped a little the drivers side
i remember a topic from ages ago on how to do it but cant remember
the details also is they a way to make my door open better as the
handle is sh!te quite dodgy to open
cheers
Offline jimbo
Re: door
« Reply #1 on: 25 October 2004, 11:10 »
you need to put a wheelbolt in the bottom door hinge and close the door slowly but firmly. if you go too far put the bolt in the top hinge to bring the door down again.
its a bit scary to start with but you soon get the feel for how much pressure to apply and then its sweet. ;D
ps put your sig pic address like this
(img)http://img.photobucket.com/albums/v72/rob04/Sigs/txtcopy1.jpg(/img)
in your signature, change the () either side of img for [] as i had to use these to show you the layout and it will work? ;D
« Last Edit: 25 October 2004, 14:41 by jimbo »
aye up me duck!
Re: door
« Reply #2 on: 25 October 2004, 13:11 »
As for the handle, is it just stiff when you press the trigger?  Take the handle off and chuck a load of grease all over the moving parts should loosen it all up nicely!
Offline VR6_ROB
Re: door
« Reply #3 on: 25 October 2004, 19:07 »
i think sumthign may of come off the trigger because when i close the door i hear sumthing rattle
i will try the bolt trick tomorrow cheers
Blue MK2
Re: door
« Reply #4 on: 25 October 2004, 19:29 »
rob so you bought the golf!
congrats mate :D
Re: door
« Reply #5 on: 26 October 2004, 10:46 »
If you like I can get a new door handle from my local scrapper for you, its dead easy to switch the lock over too.
