Author Topic: Will Diagnostic Check find a faulty relay  (Read 1210 times)
Offline GGGti75
« on: 21 January 2010, 14:49 »
I know this may be a siilly question, but here goes.... Will a diagnostic check find a faulty relay? i've just found out my mechanic didn't use his diagnostic equipment after carrying out the repairs that were needing done, once he had done them there is a problem with the car running now after about 2/3 miles it just chucks it. After asking for some advice i was told it could be ECU or fuel relay.
 Thanks in advance
Offline axewielder
  • 95 dragon 8v
Re: Will Diagnostic Check find a faulty relay
« Reply #1 on: 21 January 2010, 17:09 »
no diag doesnt find faulty relays, they are a pretty cheap+ easy first try though
Offline Cable
« Reply #2 on: 21 January 2010, 17:11 »
it will pick up a problem ie. open circuit, but it wont tell you that its a relay
Offline axewielder
  • 95 dragon 8v
« Reply #3 on: 21 January 2010, 17:13 »
rly? all i heard was that it didnt on the mk3? ne way good luck finding the fault, ive been there+ so have lots of us  :rolleyes:
Offline GuessWho
« Reply #4 on: 21 January 2010, 18:58 »
Yup.
Snap On tool I use at work just displays "Open circuit" then gives an error code to what circuit it is.
Offline GGGti75
« Reply #5 on: 22 January 2010, 08:25 »
Nice 1 guys. Hopefuly gettin it checked out today, i'l let you know how it goes
