Author Topic: help this weeks problem with the mk3  (Read 1438 times)
Offline babyvw
« on: 19 January 2010, 07:37 »
help help  :cry:
my stero's stopped working in my golf was working on way home monday and then this morning its stopped checked fuses all ok any idea's need answer and it solved my 7 tonight as i did the scarey thing of thinking all the way into work this morning!! and it take me 30 mins to get ere lol!! :laugh:
my mk3 8v for sale 700 or offers
Offline justalex81
Re: help this weeks problem with the mk3
« Reply #1 on: 19 January 2010, 08:32 »
there's usually a secondary fuse at the back of the stereo. have you checked that?
Offline oggy
« Reply #2 on: 19 January 2010, 09:04 »
If it works when ignition key is just inserted then not a fuse - probably the switched live feed connection to the ignition switch - yellow/red wire. Re-route the wire for the stereo to another switched live feed - blower?
If it doesn't work at all then yes - could be fuses, but then could be anything really. Check live feeds are actually live to stereo with a multimeter or 12v lamp to earth.
Offline VR6-Joe
« Reply #3 on: 19 January 2010, 15:04 »
Possibility it could even be the ignition switch. Had this problem on my first Mk3, it had worn so much, the only way you could get the stereo to come on was by pushing the key in and holding it there.. which you can't really do whilst driving lol!
Gone but not forgotten;
1983 Mk1 Golf GX - 1991 Mk2 Golf GTI - 1988 Scirocco Scala - 1989 Mk2 Golf CL - 1993 Mk3 Golf Ryder - 1996 Mk3 Golf SE - 1996 Mk3 Golf CL - 1995 Mk3 Golf GTI 16v - 1996 Mk3 Golf VR6 Highline - 2003 Saxo VTR - 1996 Mk3 Golf VR6
Offline boneybradley
  • Back in a Mk3...
« Reply #4 on: 19 January 2010, 18:34 »
wiggle the key and if it turns on then its the ignition switch/barrel (both common issues and not that easy to do!)
Offline babyvw
« Reply #5 on: 19 January 2010, 19:55 »
well it werent fuses and tried igntion thing to and fuse on back of stero nothing i thinks it maybe just dead and gone to the stero's of hell as it played lots of heavy metal lol will have proper fiddle with it tomos!!
thanks for help guys
